G37s (at) Best Power Adding Mods !!!
Old 05-25-2008, 11:56 AM
Mrbig19
Mrbig19's Avatar
Lightbulb G37s (at) Best Power Adding Mods !!!
What Are The Best Performance Mods That Can Be Done ! Where To Buy Them As Well.....
Old 05-25-2008, 12:34 PM
VRG37S
VRG37S's Avatar
Well best power adders would be intake, hfc's or test pipes, exhaust. That's about what is available as of right now. The Injen intake should yield I believe 16 hp. For exhaust Fast intentions yielded I believe 14 just with there exhaust system. Hfc's should yield about 8-10hp and test pipes should be around 13-15hp. Keep in mind you get a whole lot more out of these mods with a reflash. Technosquare has something available for that. Talk to DieselDoug22 for more info on that. Companies currently that have performance products available for the g37 are (Fast Intentions, Berk Technology, Stillen, Fujita, Injen). I believe that's it but if I forgot someone else please correct me. Anyways good luck and hope this helped you. HAPPY MODDING!!!!!!!!
Old 05-25-2008, 01:45 PM
Mrbig19
Mrbig19's Avatar
Very helpful thanks........Just looking to gather lots of info trying to built a car for my shop, thanks......
Old 05-25-2008, 01:47 PM
Mrbig19
Mrbig19's Avatar
The reflash i really need more info on.....
Old 05-25-2008, 01:52 PM
VRG37S
VRG37S's Avatar
PM DieselDoug22 he is on the forums. They used his car to make a prototype off of. So now some reflashs are available depending on what options you have. Such as 6mt with navigation and not the cruise control I forgot what it's called. But depending on your options on you car they have different reflashs available. However Doug said it made a huge difference in all areas of the car. Hope this helps!!!!!
By the way the place is called Technosquare. Call them up if you have a car with options they haven't tried you might be able to get it for free. By letting them use your car for R&D
Old 05-25-2008, 02:11 PM
MaxToTheG37
Super Moderator w/ Boost
MaxToTheG37's Avatar
Read the 411 section here before you do anything else
Old 05-25-2008, 03:48 PM
The1andOnly
The1andOnly's Avatar
What's gonna make them all come alive will be the Cobb access port. It's gonna be a bit more pricey than the tecnosquare reflash but it's WELL WORTH the extra you spend since you can basically change your tune settings with different maps. It also provides security with it's anti-theft and valet-setting.
Old 05-25-2008, 03:58 PM
fireboy
fireboy's Avatar
yeah you left out AAM, and GTM are the two shops that have Turbo kits completed and running,, just depends on if you live onthe east or west coast
Old 05-26-2008, 11:34 AM
Mrbig19
Mrbig19's Avatar
Really turbo kits whats the pricing for them ?
Old 05-26-2008, 12:40 PM
fireboy
fireboy's Avatar
hey man yeah there out... it would probably be best to contact them to get the exact price.. both kist are in house installs...
Old 05-26-2008, 01:53 PM
da mayor
da mayor's Avatar
vinnytenracing.com is working on something
Old 05-26-2008, 06:37 PM
AZg37
AZg37's Avatar
I was quoted 10k for the AAM kit and 15k for the GTM, GTM kit has better HP/TQ gains from what I've seen.
SkylineG
Intake and Exhaust
13
10-03-2018 07:56 PM
nethole
08-12-2015 04:08 PM
zero260
08-12-2015 10:02 AM
350zrunnin12s
08-09-2015 09:55 PM
Quick Reply: G37s (at) Best Power Adding Mods !!!
