Sponsored By:
Sponsored By:
2011 G37X Starts and Stalls
Old 12-13-2013, 01:40 PM
Mowbr4
Mowbr4's Avatar
Hey everyone,
I did some research through the forum and saw that this issue could be related to a battery but wanted to see if anyone had the same exact problem.
Today for the first time, I tried to start my car, it started and stalled out right away. It did this for three consecutive times. On the fourth time, the car finally started and idled WITHOUT stalling out.
I drove it for about 15 miles, it seemed fine. Once I get to where I needed, I turned it off. I gave it 5 minutes and tried to start it again, it started and stalled. Then I tried a second time and it worked.
Has anyone had similar issues? If so, does anyone know what the issue is?
My car is a Leased 2011 G37X. It is cold also, about 30 degrees out.
Thanks.
Old 12-14-2013, 12:54 AM
gyukang2
gyukang2's Avatar
Mine is 2009 gx coupe and samething happened the next winter in 2010.
However, everything has been fine once it happened.
I don't know why, but don't worry too much
Old 12-14-2013, 04:17 AM
Darth Kinetic
Darth Kinetic's Avatar
Call Service. Drop that lease off
Old 12-14-2013, 07:52 AM
SwissCheeseHead
SwissCheeseHead's Avatar
30 degrees is not cold. Take it to the dealer. That's not normal. You should worry about it.
Old 12-15-2013, 05:22 AM
SPDCRZ
SPDCRZ's Avatar
MAF sensor. Had this issue when there was a gap between the intake and the manifold.
When cold out the sensor may malfunction too.
Only other option can be the A/F mix which wouldn't really be happening with a car that's mostly stock.
Old 12-16-2013, 11:21 AM
Mowbr4
Mowbr4's Avatar
Thanks everyone for the replies. My car has not done it again since I posted this. If it occurs again, I will take it to the dealer.
Since it's a lease, it's their issue. My lease is almost over. :-). I have to fix a few bumps on the car before turning it in though.
Thanks again!
Old 12-16-2013, 12:41 PM
farmurr
farmurr's Avatar
Best advice on the forum lol
91dx
08-01-2016 10:46 PM
timc00k
09-05-2015 05:12 PM
ryang37x
08-21-2015 03:27 PM
Quick Reply: 2011 G37X Starts and Stalls
